Tot ce stiti... tips, tricks...
Edited by admin at 20-01-2008, 16:09
Discutii generale despre Windows
8 090 vizualizări
537 răspunsuri
Linkuri topic "Discutii generale despre Windows"
2012 mesaje
30 august 2005, 23:02:03
lol...deschide topicul asta in engleza si am sa iti postez tips and tricks pana te plictisesti sa le citesti si, daca le pui in aplicare, sa iti pice windows-ul din ora in ora
Sau vreti sa postez aici chiar in engleza?
1398 mesaje
din 08/06/2005
Nokia6230i
30 august 2005, 23:53:59
3d posteaza
2012 mesaje
31 august 2005, 20:28:17
Create a shortcut to lock computer
Right click on desktop and select new -> shortcut. Then copy and paste this in the program location box "rundll32.exe user32.dll,LockWorkStation" Click next and enter a name for you shortcut and then click finish. Now you can copy and paste that shortcut anywhere you want on your computer.
Edited by 3DwarD at 31-08-2005, 21:15
613 mesaje
din 21/06/2005
SonyEricssonK500i
31 august 2005, 21:12:49
What do you think about the last operating system of microsoft WINDOWS MEDIA CENTER have you tried it on your Pc?write here your opinion about it?you probably want to ask me what do i think about it!well,i'm not satisfied at all. I think i said enough,..
Mod Edit: Oh...I forgot to say that it's not compatible with some programs that in win xp usually work
Edited by 3DwarD at 31-08-2005, 21:17
2012 mesaje
31 august 2005, 21:16:48
How to really get rid of unneccesary software
to uninstall things like msn messenger and other hidden installs thru add remove programs, do this:
find sysoc.inf (you might have to enable "show hidden files" and "show hidden/protected system folders" in explorer) and open it in notepad
replace all ",hide" with "," (both with out quotes) which is easiest to do with the replace all command under edit
then in add/remove programs under add/remove windows compnents and whole new list of things to uninstall and add are now listed (such as internet explorer)
1759 mesaje
din 28/06/2005
01 septembrie 2005, 03:12:21 • actualizat 01 septembrie 2005, 03:12:42 (1 ori)
Totusi mai bine postati in romana, nu toata lumea stie engleza, de exemplu eu nu stiu .
2012 mesaje
Nokia6600
01 septembrie 2005, 09:15:26
Pai atunci cum te descurci in win? Sau ai in romana?
4227 mesaje
din 01/07/2005
SonyEricssonT300
01 septembrie 2005, 13:01:05
Off-topic:
Nu pot sa sufar windows-ul in romana. Imi ia cu 2-3 secunde mai mult sa fac o "reimprospatare"
1759 mesaje
din 28/06/2005
04 septembrie 2005, 03:25:10
@3DwarD Da am windows-ul in romana si aproape toate programele de pe calculator in romana, oricum la multe m-am obisnuit si cu versiunea in engleza la ghiceala (de ex. Macromedia).
4227 mesaje
din 01/07/2005
23 ianuarie 2006, 20:08:15
Stie cineva cum pot sa micsorez latimea de banda care si-o aloca windowsul pt automatic updates? Auzisem ca default este 30% si se poate micsora dar n-am gasit nicaieri.
227 mesaje
din 11/12/2005
24 ianuarie 2006, 18:13:08 • actualizat 24 ianuarie 2006, 18:13:52 (1 ori)
3dWARd 31-08-2005 20:28:17
Create a shortcut to lock computerRight click on desktop and select new -> shortcut. Then copy and paste this in the program location box "rundll32.exe user32.dll,LockWorkStation" Click next and enter a name for you shortcut and then click finish. Now you can copy and paste that shortcut anywhere you want on your computer.
2121 mesaje
din 13/12/2005
03 februarie 2006, 19:56:57 • actualizat 03 februarie 2006, 20:27:18 (3 ori)
xp sp3
http://xs66.xs.to/pics/06055/xpsp3.jpg
cine a instalat sa ne explice si noua, ceilalti va puteti da cu parerea...
nu sunt artist ca sa ma preocupe "aspectul"
519 mesaje
din 05/08/2005
03 februarie 2006, 20:06:06
@MARU - resize la imagine ca ai stricat aspectul paginii!
Informatii despre Longhorn stie careva? Se mai lanseaza?
352 mesaje
din 11/01/2006
03 februarie 2006, 20:18:15
He he! Longhorn a decedat demult. A aparut in schimb Windows Vista. Care e in teste de mult.
Înapoi la Sisteme operare
